| Home > Help Needed / General Tech Chat > pre-avon help needed, trying to figure out my RR graph. | |||||||
14th Jul, 2006 at 01:18:28am
had my car on the rollers today so i could get it checked over and up the boost to 15psi for avon but things haven't turned out too well really.
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
14th Jul, 2006 at 09:10:36am
hc to co ratio is a good way of indicating cam timing, i.e if the hc's are high and the co is low then your cam timing maybe out by a significant amount.
14th Jul, 2006 at 09:28:16am
bud , the poppng nd banging sounds like a lean patch , is yuor fuel pressure regulator keeping the fp above boost at that point ? the torque its putting out at 4500 seems good and would not suggest bad cam timing ,do you know what the mixture was on the rollers after 4500 ? ,do you have points or electronic dizzy ,have you closed the plugs up to say 20 thou to eliminate spark faliure and tried that ?
14th Jul, 2006 at 09:54:06am
cheers chaps, i'll check out the fuel pressure later and make sure its all ok and rising with boost.
14th Jul, 2006 at 05:35:04pm
Just got back from work and had the opportunity to look at the graphs....
14th Jul, 2006 at 10:22:36pm
after you have tried out all the above budd
Edited by BENROSS on 14th Jul, 2006.
