Home > Help Needed / General Tech Chat > Dump Valve Dont work
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
Hi Ive recently got my mini going. I`ve plumbed in the bleed valve and dump valve by putting two T pieces in the vaccum pipe from the plenum to the fuel pressure.
The Dump valve dont work I got a twin piston type. So i lent my brothers dump valve to test if that worked which is also a piston type and that didnt work either all I hear is alot of Turbo chatter.
Im I using the wrong type of dump valve? Any advise please thanks
think you have the plumbing all wrong!!
bleed valve goes between the actuator and either the plenum or the compressor housing on the turbo
fuel pressure should be connected to the plenum
dump valve should be connected to the inlet manifold AFTER the carb butterfly
