Home > Help Needed / General Tech Chat > turbo shaft play?
wetshed
Member #: 1117
grimsby
is it true that there is always play on the shaft on the turbo? and it is reduced when there is oil in the turbo? is it the bearings on the shaft thet make it move? If you could help me that would be great. thanx neil
bert motorsport. win it or bin it!
there is some "slight" play in the lateral & axial
refer to the Haynes manual and use a DTI to check clearances
i have next to no play in the turbo thats just let me down
on a new turbo, there is as close to ZERO axial, and somet like 1 to 1.5mm or so radial movement at the tip of the compressor nut.
The compressor should not touch the side of the housing however. if it does, be suspicious.
Edited by turbodave16v on 18th Jul, 2006.
