Home > Help Needed / General Tech Chat > camshaft enfloat
Leonard
Member #: 806
Cirencester, Gloucestershire
i seem to have to much camshaft endfloat in the engine im building. unless im missing something, is it the triangular plate and the oilpump that control the enfloat?
Kean
Member #: 341
aka T2clubby
South Staffs
No, you need to fit the timing gear to check the endfloat buddy
Leonard
Member #: 806
wow that must be a record time reply. i suspected this, but the GAYnes manual say put the cam in and check the endfloat, then fit the gears. but then theyre a bit special. cheers for the help
