Home > General Chat > how much do you think i would get
t@z
Member #: 452
Chester, UK
i'm thinking of selling my turbo engine subframe brake set up etc so i can just start to save for another conversion
here is the details
New Built Engine, Metro Turbo Block Bored To 1293Cc, New Omega Pistons 5mm Dish, Standard Turbo Crank, New Mains, New Bigends, Centre Main Strap, New High Pressure Oil Pump,Big Vave Head, Polished Ported, Broze Guides, New Double Heavey Duty Valve Springs, Standared T3 Turbo, New Avonbar 13 Psi Actuator, New Grp A Dump Valve, New Avon Bar 10 Psi Carb Needle,New 2" Avon Bar Down Pipe, Rs Turbo Inter Cooler Front Mounted, New Hell Oil Cooler With Braded Hoses, Recon Turbo Gear Box With Cenre Oil Pick Up, Duplex Timing Gear, Standart Turbo Cam, Side mounted Rad, All New Gaskets And Seals.
Brakes Include 10" copper S set up new calipers, discs, pads and hoses and braided hoses.
just got it back where i had new AP racing clutch fitted and grey diaphram to handle the power as it seemed to be slipping a bit when tested it on boost.
you get here is a slide in turbo engine that runs sweet with good power. needs to be rolling roaded as have only had it on the road for a month or 2 and in that time not used alot due to me ahving a daily drive.
your advice please and thanks
T
www.twitter.com/lilpinkiy
Carl
Member #: 95
liverpool-on-sea
on ebay probably a 150 to 200ish quid for you brakes if in good condition.
engine ebay it i rekon somewhere inbetween 500 quid and 1000ish? maybe a bit more.
id say leave it all in the car so the buyer can test the engine first offering to do this might get you more. why not offer the fuel pump tank etc so the buyer can buy the full shebang!
Edited by Carl on 24th Jul, 2006.
also a quick RR with some power graphs and people knowing its a good one would pay for itself for sure.
Turbo Shed
Member #: 30
Epsom, Surrey
I think its worth £20 for the lot.
i just so happen to have a crisp £20 note ready and waiting! lol
