| Home > General Chat > Attn fab. T2 hybrid? | |||||||
25th Jul, 2006 at 01:36:46pm
i hope this works. here should be some pics of my T2 that i was told is a hybrid.
25th Jul, 2006 at 03:52:35pm
it look like a std renault 5 gt turbo ,
25th Jul, 2006 at 03:53:37pm
which are the numbers on the turbine housing? |
25th Jul, 2006 at 04:30:13pm
just had another look at it. there are no markins on the exhaust side. inlet wheel casing has 988 13 stamped in it but this could be aftermarket markings
![]() 6753 Posts Member #: 828 Post Whore uranus |
25th Jul, 2006 at 04:55:32pm
russel try to measure to size of the inlet wheel where you see the blades .same for the turbine wheel ,and see if theres an a/r no ,on either housing . oh and a plate on the centre section with any nos on it ?regards robert Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
25th Jul, 2006 at 04:59:24pm
there are no numbers and no plates etc. will go and measure the bits i can see |
25th Jul, 2006 at 05:25:06pm
ok mesurments taken with top quality plastic office ruler!
25th Jul, 2006 at 07:35:29pm
37mm compressor impeller: t2 60 trim so a high flow T2
26th Jul, 2006 at 02:13:13pm
OK i have checked again and there is nothing at all on the exhaust scroll or bearing housing. the only thing is stamped on the end of the outlet to the carb and that is 988 13.
27th Jul, 2006 at 07:20:19am
you have pm |
27th Jul, 2006 at 08:56:32am
fab i have the r5 turbine down as 35.5mm?? are my specs wrong ? they may well be iv not measured one personally ! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
27th Jul, 2006 at 11:24:57am
I mesured one of my turbos, which have a std turbine wheel, and it seemed to be 37mm,I checked technical drawings and it should be 35.5. This wasn't mesured in good conditions, so 1.5 have certainly missed |
27th Jul, 2006 at 02:16:45pm
Thanks for you help. i will fit the turbo i have and see how it goes.
