Home > Help Needed / General Tech Chat > Got hold of a T3... but....
Robin
Member #: 1167
Northants
... i need a banjo type bolt to get the oil feed on (i think)
where can i get one?
and what sort of boost level should i be setting it to on a standard engine? 6psi or 8?
i have a selection of carb needles too, so i can adjust the fuelling if i need to
would anything need uprating to take 6 or 8 psi?
avonbar for your first question
your on the limit with 8psi on a standard engine
the standard turbo needle with just cope with this
you can get a 8psi modded needle from avonbar
Robin
Member #: 1167
Northants
cheers.
Avonbar will be getting my custom very soon then
Robin
Member #: 1167
Northants
i should be able to get hold of one fairly cheap if i go for the 2WD saff one
i'll look into that
cheers for the suggestion
giallofly
Member #: 164
The Stig..
Newport Pagnell
Or ask Mr Flanigan?
Robin
Member #: 1167
Northants
you have an intercooler going as well?
giallofly
Member #: 164
The Stig..
Newport Pagnell
No sorry, bango's etc.....
Robin
Member #: 1167
Northants
ok cool, i'll grab one off you when i pick up the downpipe
