Home > Help Needed / General Tech Chat > what CR ?
Richie
Member #: 628
sorry i have not yet gone through the search bar, my comp seems to crash when i do it :(
if i plan on running between 12 - 14 psi boost with phase 2 cam, what cr do i need ? how much do i need to get milled off the pistons (if anything) or can it be taken from the head ?
Richie
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
what pistons are they?
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=7827
Richie
Member #: 628
cheers Iain my pistons are the stock 1275 turbo ones, not sure what cc the dish is though. the pistons are stamped on the crown with --> 2083|1D17 and the letter A stamped in the middle. iam prepared to use octane booster if needed, i used to have to run 101 octane with my old n/a engine the car is not an everyday car.
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
if your running an intercooler, I'd aim for about 8.5:1
Richie
Member #: 628
cheers , is there a set amount to mill out of the head ? i would prefer to take it from the head as i will have to have my pistons taken from the rods and the rings removed.
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
giallofly
Member #: 164
The Stig..
Newport Pagnell
Like jim says, 8.5 is a good compromise.
Off boost power and room for some boost.
Have the pistons machined if possible, i know from experience you can find 15cc out of them and volume in the piston is ideal.
Richie
Member #: 628
ok cheers again, iam going to have to very carefully remove my new rings and get take my pstons for a trip to the laithe
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
On 28/07/2006 15:08:31 my first turbo said:
cheers Iain my pistons are the stock 1275 turbo ones, not sure what cc the dish is though ?
Stock Turbo pistons have a 12cc dish. *smiley*
Richie
Member #: 628
cheers phil, so what boost could i safely runn with a 2wd cossie cooler n phase 2 cam with that cc dish ?
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
minimark
Member #: 19
newcastle
12cc ..bit oppitisitc ( spelling) ,work out your c/r, 1275/4/ + all the air (ie piston dish +head camber cc +ring land + deck to piston height) and / by all the air
minimark
Member #: 19
newcastle
rr it as there is no safe figure if you have fueling and timing wrong !!
i ran 8.5:1 ish....... with stock pistons on 105 ron with 28cc chambers with a crap! intercooler
and it made the goods
i can do you the chambers if you want rich ?
pm me
Richie
Member #: 628
will pm you.........Mark i know what ure saying, but i dont want to build her up then strip her down to lower the cr to get the psi boost i want, looks like the pipette will be coming out then :(
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
