| Home > Help Needed / General Tech Chat > spi tank?do i need an uprated fuel pump? | |||||||
28th Jul, 2006 at 10:08:08pm
hi, hope someone can help. i will be using an spi tank with my turbo conversion, was wondering if i need an uprated fuel pump too? also, what oil pump is recomended?is a standard pump up to the job, bearing in mind it wont be compleately standard? any advice would be apreciated, thanks. oh, and is it a good idea to use an rs turbo intercooler? i have made a cardboard copy using the measurements of the cooler, and it will fit if i move the coil. was wondering how effective these intercoolers are, as there seem to be plenty on ebay. thanks |
28th Jul, 2006 at 10:09:45pm
series 2 rs turbo intercoolers are a good start. as are cossie ones, or TD5 ones.
28th Jul, 2006 at 10:19:06pm
hi welsh dan
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
29th Jul, 2006 at 08:03:29am
As has been discussed before the spi tank is only good for 1bar of fuel pressure, so it wont cater for more than 10psi of boost pressure. If you wish to run more then it might be an idea to look at another pump I've seen the future and tbh its Pie
29th Jul, 2006 at 09:41:45am
29th Jul, 2006 at 05:00:18pm
i think the spi will do more than that to be honest. i had a mini running 12psi on one fine.
29th Jul, 2006 at 05:17:32pm
SPi rail pressure is 1 bar, that doesnt mean its not good for more, i recon its good for 2 bar fuel pressure at least. The MPI rail pressure is 3 bar, so should be good for 4 bar
Edited by Sprocket on 29th Jul, 2006. On 26th Oct, 2004 TurboDave16v said:
10th Sep, 2006 at 12:11:13am
Sorry old post i know but this is worrying me slightly as i have just bought an spi tank, will the standard pump be ok? has anyone tested the pumps? cheers |
10th Sep, 2006 at 01:30:37am
I knew of a lad several years ago who ran around 1.2bar with the SPi pump.
10th Sep, 2006 at 12:52:04pm
i'm looking at running 20+psi boost btw. |
