Home > General Chat > Safety Devices Rollcage...
Dogmatix
Member #: 851
Hereford
Where can I get myself a new, safety devices roll cage?*blush*
jimmy
Member #: 829
essex
try this mate it`s a start for you
http://www.safetydevices.com/content/view/6/34/
1293 Turbo mini
Dangerous
Member #: 417
I think they make them abroad now,so you have to find somebody to import 10 at a time
Richspec
Member #: 300
Cumbria
minisport??
used to be cheaper to get from there than SD!
Here for the craic..
Supercharged Arden powered
i personally think rollcentre have better doorbars
there also made in the uk
Dogmatix
Member #: 851
Hereford
Any more info there Wolfie...
I want a full race cage, with door bars, dash bars, the lot.
jimmy
Member #: 829
essex
look on ebay
1293 Turbo mini
http://www.rollcentre.co.uk/
i would not buy a cage from abay as you dont know if its been knocked about
i have an fia rollcentre and it fits really nice
jimmy
Member #: 829
essex
look what i found
http://cgi.ebay.co.uk/OMP-ROLL-CAGE-6-Bolt...1QQcmdZViewItem
1293 Turbo mini
Dogmatix
Member #: 851
Hereford
Thanks Wolfie.
I've sent an email to them enquiring on prices etc.
Scruffy
Member #: 328
Seaford Rise, South Australia
The cage shown is a weld in type which requires a specialist install and is not for the DIY welder. You may be better off with a six point cage (bolt in). Do not be tempted to go the safety devices multipoint cage route as this is UBER HEAVY and bolts in.
If you want to go the weld in route go for some one like custom cages or rollcentre who will certify their work and will be to an MSA standard - so no probs if you ever decide to race the car or sell it to someone who does (and will give it a better resale value if you ever decide to part with it)
Some pics of my rollcentre cage which was done in 1995 using a CDS kit from roll centre and took a specialist two weeks to do.
Edited by Scruffy on 31st Jul, 2006.
On 5th Sep, 2011 Vegard said:
Scruffy
Member #: 328
Some one help please why does the picture not appear without clicking link? Is this a firefox problem as i used the image button to load these? You need to put img and /img in the square brackets, not url and /url. TF
Edited by Tom Fenton on 31st Jul, 2006.
dan
Member #: 93
just a few points..
talk to mr endaf owens on this one, and also think about just how much tubing you want/need
for instance i've got endafs old miglia and its got a bit more tubing than say jimsters and a slightly heavier gauge for optimum strength & stiffness (both made from t45), obviously jims overall cage weight is lighter than mine
check out
http://www.owensfabrication.com/index.html
i've also seen a safety devices weld-in cage being put in, and there's fairly minimal amount of tubing, with just door bars, dash bar, and rear double diagonal, not sure if it was only available in CDS, it also didn't come notched which was a bit of nightmare for the welder putting it in! Also don't forget things like steering column mounts
got a feeling custom cages did a multipoint race cage (more tubing than the safety devices one), in t45 was about £2kish fitted
