Home > Help Needed / General Tech Chat > Cracked oil pipe! :( :( :(
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Argh! just noticed that the oil pipe that comes from the engine block to round the rear has cracked! Its splid just on the join to the ring that goes round the bolt on the block front, its not fully come away, just twisted apart.
Ive been to the only welding places i know arround here, but they are more panel welding places. Is there anyone on here that will do it? Its quite fiddily, but i heard these are hard to get hld of? ARGH!
jamesfawcett
Member #: 218
Will get a photo tomorow. Just was wondering, if anyone knows somone/is somone that could do it, im willing to pay to have this repaired and can post it, just dreading this holding the conversion up :(
thanks!
giallofly
Member #: 164
The Stig..
Newport Pagnell
i have one...
better still have a flexi braided line made up, they are by far better and easier to fit and work with..
Edited by giallofly on 10th Apr, 2004.
jamesfawcett
Member #: 218
Cool! Do you know any companies i could check out?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
minispares or your local hydraulics specalist!
alex
AlexF
Carl
Member #: 95
liverpool-on-sea
avonbar
jamesfawcett
Member #: 218
great stuff.
jukka
Member #: 60
Forgotten more than most ever know
Been there done that. Only I did it while driving ! I had a good laugh when I noticed that someone?s car had leaked a long line of oil on the tarmac... until I remembered that I had driven that route only 5 minutes earlier and was in fact following my own tracks... also my back window was somewhat oily ! I had to put 5 litres of oil in the engine. I started the engine to see where it leaked and found a crack in the steel line. It was a simple fix with hydraulic hose and 4 jubilee clips so I could drive to a hydraulic shop to have a steel braided hose done. Make sure that they know it is for turbo application. Mine has teflon liner to cope with the heat. Anyway, I ended up driving the whole summer with the temporary fix since it was pain in the a** to get at the banjo bolt at the turbo.
Jukka
