| Home > Help Needed / General Tech Chat > 1st turbo build? | |||||||
1st Aug, 2006 at 12:06:20am
hi, will be building my turbo engine very soon (starting in the next month or so)
1st Aug, 2006 at 12:17:41am
oh, and does anybody have any idea what power this spec would give if put together well? was hoping for plenty of torque and at least 100 bhp? guess the engine will run at 4 psi to start with, obviously nobody can tell until its on the rollers, but was hoping to fit adjustable boost to about 8-10 psi. what improvement in power would this give? would an engine of my spec be likely to cope with it or will it probably go bang?i know its hard to tell until the car has been on the rollers, but is that range about right? thanks again |
1st Aug, 2006 at 12:25:13am
NA MG Metro cam is the one to use if on a budget, don't bother with the conventional fast road cams as to be honest they won't work well with the turbo.
1st Aug, 2006 at 12:26:27am
8-10psi sounds a bit optimistic without any work to lower the compression. This should be your main priority to be honest.
1st Aug, 2006 at 12:30:11am
if your on a budget
1st Aug, 2006 at 12:54:06am
hi, how do you go about opening the chambers?do you mill them? how much do you take out?my dad is an engineer but wont use the computer so asking so i can tell him, mayb he can do the work |
any advise would be apreciated, thanks
