Home > Help Needed / General Tech Chat > Turbo fuel pressure regulator on NA engine
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Im using the turbo fuel pressure regulator on my NA engine just for now until i get the next turbo engine, what do i do with the top connection? the plenum pressure connection?
Do i vent it to atmosphere or block it off?
Im thinking, that at the plenum it will never see vacuum? So this is making me think not to connect it to my inlet is that right?
andeh
Member #: 97
Near Daventry, midlands
Nope, i asked this a while back and was told to leave it vented to atmos, doubt it'd harm attaching it to the inlet though?
Nick
Member #: 154
Midlands
i'd just block it off and set it to 3/4psi ish personally.
block it off or leave it to air.
doesnt matter.
personally i'd block off so nothing crawls in.
jimmy
Member #: 829
essex
Just be ok if you cable tie it up out of the way and check the fuel pressure is about 3psi
1293 Turbo mini
or any spanners/washers fall in it
andeh
Member #: 97
*laughing* how big is your reg nic?
