| Home > Help Needed / General Tech Chat > Its a non starter! | |||||||
4th Aug, 2006 at 08:38:12pm
Hi All, firstly let me introduce myself, im Mark in Telford, Shropshire, with a 1978 clubman turbo, i have been using all the helpful advice on this site for the past year while i set about rebuilding my mini. And have so far not had too many set backs.
4th Aug, 2006 at 09:01:35pm
You are right about the timing, it could easily be so far out that it won't start. Assuming that you are using a dizzy. read the Haynes manual on how to set it up. I mean the whole how to install bit and everything.
4th Aug, 2006 at 09:07:15pm
Don't overlook the obvious, firing order 1 3 4 2.
Edited by giallofly on 4th Aug, 2006. On 21st Jan, 2011 fastcarl said:
4th Aug, 2006 at 09:09:34pm
Yep make sure you have 2 and 3 the right way round :$
Edited by Dangerous on 4th Aug, 2006.
4th Aug, 2006 at 09:53:08pm
Thanks for the info, will have another read of the Haynes see if i have missed anything on the set up. See if i can get the timing sorted.
567 Posts Member #: 102 Post Whore Pennsylvania USA |
4th Aug, 2006 at 10:20:44pm
Yeah when I used a dizzy and the first time I tried to fire it up I had the dizzy drive shaft in 180 Degrees out and I got the same result you did. Check the drive is in the correct way. |
4th Aug, 2006 at 11:04:30pm
ha, "when i used a dizzy"!!
5th Aug, 2006 at 12:18:58am
It makes one hell of a difference with mapped ignition and it aint that expensive. |
5th Aug, 2006 at 12:47:29am
I'd say its definately your ign timing buddy.
5th Aug, 2006 at 11:30:03am
have you got the leads 1 3 4 2 anticlockwise
5th Aug, 2006 at 01:16:13pm
Thanks for all the help but it still wont start, Edited by MarkGTT on 5th Aug, 2006. |
5th Aug, 2006 at 02:21:58pm
swap plugs 1 and 4, and 2 and 3.. jsut incas3e your 180 degrees out, i know you checked but you never know. aklso "dry" the plugs wiht a blow lamp or over a gas cooker. turbo 16v k-series 11.9@118.9 :)
5th Aug, 2006 at 07:02:37pm
Just tried swapping the HT leads and drying the plugs off as above but still no joy.
5th Aug, 2006 at 07:25:24pm
Yep, lift the dash pot with your finger a squirt a SMALL amount down the carb mouth, obviously with the plenun off.
5th Aug, 2006 at 07:27:03pm
I use a inkjet refill shringe and squirt approx 10-15 ml down the hole where the vacuum pipe goes just infront of the carb
5th Aug, 2006 at 07:30:16pm
Great tip Dangerman!
5th Aug, 2006 at 07:42:16pm
Ok thanks will give it a try, choke cable isn’t on but been moving it open manually when turning it over..
6th Aug, 2006 at 05:30:58pm
Due to me trying to start the car for the past few days the battery has now gone flat.. however I think I have cracked it, the timing was still 180 out, think I must have been timing it on the wrong stroke. |
