Home > Help Needed / General Tech Chat > 10mm 1" plugs
Hello,
Now I've got my 7 porter back from V max I'm looking at the injection and ignition system, Had my megasquirt running on the dining room table last night!!
Problem is I was using some crappy leads and plugs that were knocking around in the garage, these keep knocking out the neghbours tv signal, and worse making the ECU and laptop go fritzy, so I need to get some suppresed leads and resistor plugs, trouble is the 7 port uses 10mm plugs with a 1" reach, has anyone come across plugs the same dimentions? are the 10mm 8 port plugs the same length?
Cheers, Joe.
http://www.spark-plugs.co.uk/pages/technical/champjpg.htm
http://www.spark-plugs.co.uk/pages/technical/ngkjpg.htm
Use these to find the numbers and then see if your local stockist can get them, and by that i dont mean Halfords *wink*
