Home > Help Needed / General Tech Chat > Please help soon - is there a seal here?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
my oil leaks got really really bad, seems to be leaking from somewhere below the radiator a litre a day just 14 miles.
ive just taken off the radiator, and all the bits to get the timing cover off.
im going to put a new seal behind the timing chain cover, my question is, is there any rubber seals, like behind the pulley or anything?
thanks
james
Dangerous
Member #: 417
There is a rubber seal in the timing cover,make sure the rear of the pulley that runs in it is not scored.
There is a half round seal behind the timing cover between engine and box.Last time I changed one of them with the engine in place I had to undo all the bolts that hold the engine to box and prise them apart a bit to get it in.
Also worth looking at would be the speedo drive cover on the end of the gearbox
in that area, working in from the pulley there is,
the crankshaft to pully seal in the timing chain cover.
the gasket for said cover
the gasket behind the plate that said cover bolts onto
the seal between the gearbox and main bearing cap.
think thats all, unless you include the speedo housing.
bah dangerous beat me to it!!*laughing*
Edited by Joe C on 8th Aug, 2006.
jamesfawcett
Member #: 218
Excellent!!!
really fast answers thanks alot, im going to go look for that seal in the timing cover i bet its that one!! i havent seen it so not changed it
same leak was on the engine when it was in the last car i thought i had changed all the seals oops!
thanks!!
back with news soon *happy*
Dangerous
Member #: 417
There should also be a large tin washer(oil thrower) on the crank,1st thing you see when you take the cover off
Can't remember which way round it goes of hand
clubminiflip
Member #: 54
nr coventry
You'll have thet leak nailed, ya sound determined enough john, keep it going, a litre in 14 miles, thats a normal sized mini leak is'nt it :oP
Star Mag
Member #: 375
Leicestershire
Make sure you put the bolts in the correct place because if the ones near the bottom are too long then they will push the timing cover and backplate away from the box. Sounds too simple but its something i have overlooked in the past!!!
jamesfawcett
Member #: 218
hi!!1 just finished thanks alot for all your advice
checked all the places you told me, and replaced the seal in the timing cover.
and thanks for the advice with the bolts too, theyre all in the right places now.
just took it for a quick spin up the road and back, and then watched underneath and not even a drip, should be ok for a while until something else starts leaking!! haha thankyou very much
neil_g
Member #: 1175
Nr Bournemouth
iirc there is an "F" stamped on the side facing outwards?
jamesfawcett
Member #: 218
yeah mine was stamped front
