| Home > Wanted > Wanted MG Metro Turbo | |||||||
10 Posts Member #: 1204 Member |
9th Aug, 2006 at 10:43:32am
Wanted complete MG Metro Turbo car. Bodywork does not matter. Needed for Turbo conversion for my 2000 W Mini Cooper Sportspack. Must be in excellent running order and preferably lowish miles. Any spec.
9th Aug, 2006 at 11:34:53am
might be worth giving this guy an email to see if its still around Crystal Sound Audio said:
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
9th Aug, 2006 at 12:24:26pm
imho, you'd do better off building up your own lump, at least you'll know the history of it. Doesn't have to be high spec and can be done for a sensible amount of cash. |
9th Aug, 2006 at 01:29:22pm
Thanks guys, I think I would prefer to have a complete car in running order to source the bits from then rebuild the engine completely to a decent spec. How much would you think it would cost to do the conversion on a mint 2000 W Mini Cooper? All I would have to spend money on would be the engine and the conversion. Thanks |
9th Aug, 2006 at 06:44:09pm
if youv e got a 2000 cooper then sureley you wouldnt want to put 20 yr old knackered engine in it would you? so youre best off building a new one and this cost depends on what spec and bananas youre after. then theres the gearbox to think about.
Edited by Carl on 9th Aug, 2006. no longer a series, but still 1.3 turbo.
9th Aug, 2006 at 08:21:18pm
What's that song buzzing round in my head....... Dreeeaaammm Dream Dream Dream Dream.
9th Aug, 2006 at 08:45:47pm
If you want an engine in a condition suitable to make a worthy transmplant, then budget on something between 1250 and 1500, and find a nice classic low-mileage turbo metro - maybe on a MG collectors forum - purchase that and rip the heart out of it and send the rest to the crushers.
9th Aug, 2006 at 09:25:18pm
I don't want a mint engine. I just want a good starting ground. The engine will be getting a full rebuilt and a few extras added. I'm not really to worried about cutting the bulkhead and welding in a box. It will be getting proffessionally done and the engine bay repainted in the factory colour. I also have a 1340cc Mini 30 with a richard longman engine and the shell was built by the MetroMini Centre when they were about. The Yellow one they had. |
9th Aug, 2006 at 09:36:58pm
i have a short block and box that was running fine but ideally needs a build Crystal Sound Audio said:
9th Aug, 2006 at 09:39:33pm
To be honest you do not need a complete metro turbo, the only specific parts you need are the manifolds, the turbo, the carburettor and the plenum chamber. For everything else either A+ 1275cc engine parts are a good base to start with, e.g. block, head, etc
9th Aug, 2006 at 09:40:03pm
Thanks for the reply. I would rather have a full engine and box with the turbo and ancillaries. Thanks anyway. |
9th Aug, 2006 at 09:43:28pm
Would it be possible to use my block which has done 39k miles? I thought the turbos had uprated bottom ends and different pistons? I would be using a Jack Knight SCCR box which I had spare when I changed the yellow Minis engine and box. |
9th Aug, 2006 at 09:48:47pm
On 09/08/2006 21:43:28 M7STN said:
Would it be possible to use my block which has done 39k miles? I thought the turbos had uprated bottom ends and different pistons? I would be using a Jack Knight SCCR box which I had spare when I changed the yellow Minis engine and box. Yes you could use your block, but to be honest I'd have thought you'd be better off flogging it complete as a low mileage MPI engine and buying a shagged £50 metro engine as suggested before. As for the "uprated bottom end" that is not really correct, the bearings were stronger than equivalent metro engines when the turbo engines were first launched in 1982, however in about 1985 all the 1275cc engines moved to the "turbo" style bearings. So any block from 1985 on is just as "strong". Different pistons is correct but any that have been in a Metro engine since new will be fucked and ready for the skip by now, so you'll be buying new ones anyway. I really think you need to do some reading on this subject. Start by reading the "Metro Turbo Engine Myths" post in the "Beginners" section.
9th Aug, 2006 at 09:53:05pm
OK thanks for your help. I know I'm not very clued up on this engine but I'm keen to learn. I fancy my Mini being a bit different to all the other coopers with the 90bhp kit which really produces 70bhp. I don't want a NA engine because my yellow one is and I fancy a change. None of my Minis are in daily use but the Cooper does get used reguarly. Edited by M7STN on 9th Aug, 2006. |
10th Aug, 2006 at 08:47:17am
Where is the mirage kit available from? Also who would you recommend buying parts from ie pistons, valves etc? I've heard Avonbar are good. Cheers |
10th Aug, 2006 at 12:29:46pm
I have been in contact with mirage motorsport. I think I am going for the mirage kit with the T2 turbo |
10th Aug, 2006 at 01:14:20pm
Sounds good, i think I'll go for that aswell. i think I'm going to get the full spec to start with. I like doing things in a oner. Thanks for your help guys! |
10th Aug, 2006 at 01:23:09pm
Don't let me disuade you from the turbo route if thats what you really want, but
10th Aug, 2006 at 01:27:29pm
and there's still not that many of them about.
10th Aug, 2006 at 04:26:20pm
"Don't let me disuade you from the turbo route if thats what you really want, but
10th Aug, 2006 at 05:13:19pm
I agree with the others in that buying a complete car for breaking isnt the best option, you can get pretty much all the worthwhile turbo parts for around £150 if your patient and keep your eyes peeled.
