| Home > Help Needed / General Tech Chat > a few unothadox questions | |||||||
![]() 43 Posts Member #: 1031 Member Swansea (S.Wales) |
11th Aug, 2006 at 04:27:16pm
hey there, have been a lurker for a while but decided id best find out some information that has not been asked yet (that im aware of).
Project - 998 turbo |
11th Aug, 2006 at 04:28:44pm
sorry for it being long winded but thought i should try and get all my points across together than all of you having to ask the same old questions... Project - 998 turbo |
11th Aug, 2006 at 04:35:58pm
if thats the case, why dont you just stick with a std metro turbo spec?
11th Aug, 2006 at 04:42:02pm
if i could find one id happily jump all over it, unfortunately in the past year ive seen one engine on fleebay, and about 3 cars, but im not willing to tear the guts out of a concours condition metro turbo. plus i couldnt afford the car to begin with...
11th Aug, 2006 at 04:50:39pm
If I were you I would just bolt a turbo on your standard 998 engine. Get the head chambers enlarged to lower the compression ratio and run 3-4psi boost pressure.
11th Aug, 2006 at 05:07:51pm
Oh! great! so id need a metro turbo unit, manifold, plenulum (sp), carb?
Edited by Coedy on 11th Aug, 2006. Project - 998 turbo |
11th Aug, 2006 at 06:24:25pm
Benross is your man for the cylinder head mods, you can send him a PM on here.
11th Aug, 2006 at 06:52:29pm
yeah forgot about the regulator and stuff, and ill need a return line yeah? ive heared that a Tpiece between the tank and the fuel pump will be as good as a full return to the actual tank?
11th Aug, 2006 at 10:35:08pm
What you say is all true Pete, I was just trying to answer his brief in the first post of having a cheap turbo conversion that won't be quick enough to get him into trouble!
11th Aug, 2006 at 11:30:35pm
not sure if its A+ or not, i know its the origional engine so its an '87 and has done a genuine 61k.
11th Aug, 2006 at 11:50:22pm
ahhhh ok, (yey) and beacuse its an a+ ill have to seriously look into the head then? just realised, would my clutch be ok? annnnd more of a silly question, will a blow off valve still sound nice on such a low boosting engine? Project - 998 turbo |
12th Aug, 2006 at 12:04:51am
At such low boost it will probably cope, lets face it you are unlikely to crack more than 80bhp, which is great going for a 998 but won't trouble the clutch or gearbox especially as long as they are in good condition.
12th Aug, 2006 at 12:15:24am
On 12/08/2006 00:03:49 mini1071s said:
My dump valve sounds nice :) I'm probably going to change it for an OEM style recirculating one though to get rid of the noise and add more stealth. right then, here comes my chavesque side...i heared a VXR around town and his dump valve seems to stutter? instead of the bottle of pop Psssssst, it more like pststststst like a snake...ish... is this a certain type of dump valve? or is his just mangled? On 12/08/2006 00:03:49 mini1071s said:
If cash is tight, give the std head a go at 4psi and optimax. Mapped MJ ignition will help with controlling detonation issues. I think the 295 is worth is but you can end up spending ages getting everything perfect and not enjoying the car in the mean time. Developing the car is the fun bit :) as i said, i havea spare cylinder head there, so ill decoke that, check it over, dump that on and hope. if i do damage the pistons/head after a while i can change to dished pistons and my other standard head, surely that will be ok then? (guessing here mind) 80??? thats the max youd expect though yeah? how much would a realistic guesstimate be? 60? 65? Project - 998 turbo |
12th Aug, 2006 at 12:18:35am
No point just dumping on a head and hoping, you NEED TO GET THE CR DOWN or it WILL NOT WORK.
12th Aug, 2006 at 12:21:38am
ok, will do, but i thought you said it should be ok on low boost with standard gubbings? Project - 998 turbo |
12th Aug, 2006 at 12:23:41am
On 11/08/2006 16:50:39 Tom Fenton said:
If I were you I would just bolt a turbo on your standard 998 engine. Get the head chambers enlarged to lower the compression ratio and run 3-4psi boost pressure. That in my opinion is the cheapest way of achieving what you are after. No, I said to bolt it on a standard 998 engine with the head chambers enlarged to lower the CR.
12th Aug, 2006 at 12:28:20am
oh yeah, sorry, my bad. its late.
969 Posts Member #: 47 Post Whore Not very sunny swanage |
12th Aug, 2006 at 08:19:25pm
carb wise just convert a n/a carb into a turbo carb witht the turbo rebuild kit..... iain on here can get them at a very good price.... imho thats the best way to go, as even a turo carb would probably need a rebuild unless it was nearly new etc..... And on the 7th day........... God created turbochargers! |
12th Aug, 2006 at 08:26:02pm
awsome, seems like most of the needed bits are available from different people on here! great stuff! just have to find a turbo and manifold now.... Edited by Coedy on 12th Aug, 2006. Project - 998 turbo |
12th Aug, 2006 at 08:32:34pm
On 12/08/2006 20:19:25 nutter driver said:
carb wise just convert a n/a carb into a turbo carb witht the turbo rebuild kit..... I have now seen this written in a number of places by a number of different people and I do not personally agree. All that can be achieved with the turbo rebuild kit is to reverse the orientation of the spindle seals so as they are sealed against pressure from inside the carb as opposed to vacuum. In addition to this, there is the breather pipe to block, and a pipe stub to drill and install. Even with this done a converted carb is not as good as the real thing as it doesn't have the machined recess for a large diameter o-ring to seal the dashpot. If you can get hold of a pukka turbo carb then do so is my advice.
