Home > Help Needed / General Tech Chat > quick question on fuel lines as i'm writing down my POA now!
clubminiflip
Member #: 54
nr coventry
i'm going to be running a fully lightened 'n' balanced 998cc, 12g295 head (1071s advice 'cheers) mirage manifolds & a t2, metty turbo fuel pump & regulator
question is i want the very simplist method of fuel supply and return routed in the car, not outside WHAT 'ID' SIZE FUEL LINE FOR 'FEED & RETURN' ALSO WHAT SIZE 'ID' FUEL FILTER BETWEEN THE PUMP & TANK, cheers guys *surprised*)
8mm feed and return will be adequate
clubminiflip
Member #: 54
nr coventry
cheers Tom! i'm now breaking open the haynes manual & vizard book to rebuild my 998 to be a rev-happy & fast spooling (i'm hoping) little b-road eating machine *surprised*p
i now have 90% of the main parts i need for the build i ust need to confirm about fuel lines!
oh where can a get the clear plastic fuel lines with the stainless fittings? i feel these may be a good option for reliabuility, but there again i can get all my normal rubber fuel piping & clips VAT FREE, is it worth the expense of the plastic pipe on a daily driver?
