| Home > Help Needed / General Tech Chat > straight cut gear set? | |||||||
12th Aug, 2006 at 10:37:59am
Hi all, i dont know much about gearboxes so was after some help, can anyone tell if this is a straight cut gear set? and what you think of the condition?
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
12th Aug, 2006 at 10:43:49am
yes its straight cut. cant tell alot about condition from pictures tho
Edited by Leonard on 12th Aug, 2006.
12th Aug, 2006 at 11:01:11am
Yes its a straight cut box, that is about all you can tell from a picture like that, and really all you could tell with it in front of you until you tool it to pieces.
12th Aug, 2006 at 11:08:53am
It doe's look pretty clean inside though, but thats not a teribly good guide to condition. On 28th Aug, 2011 Kean said:
12th Aug, 2006 at 12:11:48pm
Cheers for the info guys, that all helps loads.
12th Aug, 2006 at 12:31:36pm
I think it's of a A series not A+ due to the studs on the side, so will be the smaller idler bearing 1/2 " as opposed to 3/4"
12th Aug, 2006 at 12:53:54pm
Also looks to have a 4 bolt mainshaft bearing retainer, which isn't great.
12th Aug, 2006 at 12:57:52pm
On 12/08/2006 12:53:54 Tom Fenton said:
Also looks to have a 4 bolt mainshaft bearing retainer, which isn't great. Mr Thicky here would like to know why please? On 5th Sep, 2011 Vegard said:
12th Aug, 2006 at 01:39:08pm
The 4th bolt drilling (arrowed in pic below) is very close to the top of the alloy casing, quite often these casings will crack from that uppermost bolt drilling to the top of the casing, or even sometimes through to the bearing counterbore.
12th Aug, 2006 at 01:57:06pm
On 12/08/2006 12:31:36 Dangerous said:
I think it's of a A series not A+ due to the studs on the side, so will be the smaller idler bearing 1/2 " as opposed to 3/4" Is this no good for the A+ engine then? whats the impact of the smaller idler bearing? could this gear set go into a A+ later casting box? sorry if these are stupid questions.. learning about the gearboxes as i go. |
12th Aug, 2006 at 02:13:58pm
12th Aug, 2006 at 04:52:50pm
yeah that looks like the weaker casing that quite a few peeps advised me not to use, but its not a real problem to swop to a different casing.
12th Aug, 2006 at 05:08:41pm
It is not so much if the gears are chipped (fairly obvious to see) but if the syncro faces of the gears are worn away (need to strip to see) as this entails new gears (a JKD 2nd gear used to be about 60quid). What make is the gearset if JKD you'll never get bits for it as JKD had nowt on the shelf when I rang up a couple of weeks ago despite the massive online Mini catalogue on their site. On 5th Sep, 2011 Vegard said:
