Home > Wanted > metro turbo primary gear and idle gear
chinlesswonder
Member #: 1192
In the garage......again!!
after stripping the engine down and finding lots of teeth missing, I now require the above.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
giallofly
Member #: 164
The Stig..
Newport Pagnell
Yes i have a full set if any use.....
Guessworks
Member #: 651
Rugby, UK
If you have lots of teeth missing, then I would be checking the faces of the transfer case and gearbox
chinlesswonder
Member #: 1192
surprisingly they are in very good condition, the primary gear has completely worn out the brass bush inside and is a very loose fit on the crank taper but hasn't damaged the crank which is odd. the idler gear has 3 teeth missing which i can't find in the housing, the gearbox cog is fine and so is the roller bearing.
keith
