Home > General Chat > well I finally got mine running
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
after endless sodding about trying to get the dissy to clear the starter motor...
and after all that she won't run unless massivly advanced (like 16 degrees..) and also isn't boosting!
It never rains but it pours huh!
Alex
AlexF
wethepeople
Member #: 176
Pre-op Transvestite
Felixstowe, Suffolk
stick with it buddy, your hard work will pay off eventually :)
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
well some dash pot oil helped!
but I cant work out why its not boosting... the turbo def works, as I took the plenum off and theres plenty of presurre there!
weird!
Alex
AlexF
giallofly
Member #: 164
The Stig..
Newport Pagnell
it wont give much boost revving it at a standstill..
is it not boosting when you drive it?
You can keep the tank if it is of use to you..does'nt owe me a penny.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
driving it is the problem, its not legal!
Before it boosted some when just reving in nutural, this time thou the guage goes to no vacum and stays there :S
But I have changed the head, which is modified...
I'll hold onto the tank for a bit if thats ok... save me getting an alloy one till my job kicks in and I have some cash!
AlexF
giallofly
Member #: 164
The Stig..
Newport Pagnell
i should come in when you drive it provided nothing is amiss..
you'll never get any boost with a t3 or a t2 without driving it, try sticking it in 3rd with the hand brake on and slip the clutch, should see boost then under load
Yep agree with that, no boost till its under load on my t3'd mini.
Sure there must be somewhere to nip about, even a stretch of drive could just do it! *happy*
Good luck with it, im hoping to drop a turbo lump back in mine over the next few months, complete fresh build so god knows what suprises that will bring!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Your more than welcome to Jon... when do you fancy a go ?
Well it boosted with a t3 before... only about 3 psi reving to 5k but it was showing...
I can't pull the hand brake on... there isn't one! It weighted too much I decided :p no seriously I couldn't be bothered to clean the cable so I junked the whole mechanism!
I'll have to give it a wirl up the road when I get the brake bleed, would probably be a touch suidial at the moment!
Alex
AlexF
Think jon meant "it should come in when you drive it provided nothing is amiss" *smiley*
See what happens when you drive mate, id tend to get the brakes sorted before then though! lol!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
LOL yeah I suppose he could...
Problem with driving it... its completely illegal on the road LOL.
Alex
AlexF
Does pose a problem, not to me as i live in the middle of nowhere with some good country roads! *wink*
where did you connect your boost gauge to before, wasn't it from the dizzy output on the carb?? is the boost gauge now connected in the same place?
Drive it up to something, chock the wheels, there are lotrs of reasons... I've never seen a T3 boost in neutral...
Maybe if you had a very restrictive exhaust before??..??..
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Boost guage is into the dizzy output... does that make a difference, I haven't given its placement alot of thought, but it is the same place as b4!
I am running a std metro down pipe which is less that 2" unlike the system which is a full 2" st8 through (even the back box).
I think I can get away with jacking the front and using the brakes in say 2nd or 3rd... that should tell me whats happening.
I agree its weird!
Alex
Edited by AlexF2003 on 14th Apr, 2004.
AlexF
