| Home > Help Needed / General Tech Chat > working out what CR to run? | |||||||
16th Aug, 2006 at 09:08:17am
just wondered if anyone can help or point me in the right direction of working out what sort of CR to run for a max of 15psi boost.
16th Aug, 2006 at 09:44:50am
with 29 cc chambers, 16cc dish, pistons flush with deck, 2,8 cc in head gasket on 1380 you are running 8.22:1. ( I have not included ringland in calcs). to get it to 8:1 you would need 1.5 cc's more dish or chamber volume. |
16th Aug, 2006 at 11:13:46am
you really are a flash bugger !! On 28th Aug, 2011 Kean said:
16th Aug, 2006 at 11:28:13am
Hmm ive only got 10cc dished pistons, but will eventually get an Avonbar head i think, would i still need to lower the compression to run 10-15psi boost? :S |
16th Aug, 2006 at 05:51:43pm
Why not use the Payen AF460 gasket with a slightly bigger volume at 3.6cc, not much more but could help.
16th Aug, 2006 at 07:55:26pm
Pete, cheers for going into so much detail. waaay over my head unfortunately, best get hold of the vizard book and have a read up on what its all about.
16th Aug, 2006 at 08:12:47pm
just to tout my spreadsheet...
AlexF |
17th Aug, 2006 at 09:12:36am
i agree with 1071 i think 9.1 with a good ic and either fixed advance to 26 deg or mj setup would be good, im currently running 12psi on 9.4cr and have run 14psi on the rollers with no probs although on 14 psi ray said here could here just a tad of det at 4k rpm but for only for a split second so i know were my limit is.
