Home > Help Needed / General Tech Chat > Metro 4-pots
1380turbo
Member #: 1211
Working up the BHP ladder.
Hi guys,
I expect a lot of you guys have fitted the 4-pot calipers.
Which master cylinder do you recommend and would you keep the dual line one? Im currently using the dual line and they have never felt as sharp as i would like. Or should i fork out for a servo?
Thankyoop
The standard dual line master cylinder will work fine with the 4-pot callipers; the cylinders of the 2 and 4-pot callipers are equivelant in size.
Fitting 4-pots, however, will not really improve you braking, or the feel of the brakes. And if you are just fitting metro cylinders then I wouldn't bother fitting them at all. only worth it for the weight saving of the alloy ones.
1380turbo
Member #: 1211
Fair enough. Got them at a good price so stuck em on there. May aswell stick wiv em.
Thanks for the info.
