Home > Help Needed / General Tech Chat > Hepolite pistons Vs original pistons
ClubmanTurbo
Member #: 1213
Cyprus
Hello guys,
I've been told that Hepolite pistons are less strong than the original pistons the MG metro turbo engine is fitted with so they can affort less boost pressure than the original pistons can. Is that right? if yes how much pressure can hepolites run?
Thank u !
IMO. the OME pistons will stand more than people give them credit for
15is psi is not out of the question i have run mine befor this latest rebuild at 16psi on full rpm and there fine
some people may disagree though?
the hepolite pistons will be good for safe levels up to 8psi
10psi + you will be in the twilight Zone!
the top of the crown to the first ring will part company if taken to excess
just my opinion
SumpNut
Member #: 28
Correct me if im wrong, but the origional pistons were made by hepolite?
i ran 16psi regularly through my hepolites last year
Nick
Member #: 154
Midlands
i run 15psi on mine aswell, same pistons as nic's.
