Home > General Chat > which gearbox to go for?
gregor
Member #: 98
Slovenia
I would need an advice. I have gearbox 22G1128 ( Cooper S MK II) in well condicioun (only 50.000km). I wonder if I should put it on my turbo engine or keep my std one- Mg Metro Turbo gearbox?
Is there a big gain to go for the 22G1128 gearbox?
your comments are welcome?
and what box do you run?
gregor
Ive been wondering what ratio's to run. Going for straight cut drops, 4 pin diff and helical box. Hope it will be strong enough for the power im hoping to achieve, 160ish.
Im looking for a good 0-60 and 1/4 times to start with.
gregor
Member #: 98
Slovenia
my plans are straight cut drop gears too, but for next season because they cost more than one my (slovenian) month salary. even 4 pin diff are just my dreams for this year.
for now I am just looking what is better choice to go for gearbox from A+ or from A engine?
I will stay on 3,22 diff ratio (I do longer trips too, this year is plan to go on IMM2004)
Edited by gregor on 14th Apr, 2004.
On some gearbox casings the bearing retainer behind the diff pinion gear has 4 retaining bolts rather than 3. The ones with 4 tend to crack across the central web ( I know, mine did). So if one has 4 and one has 3 use the one with 3.
Otherwise (if they are both the same) I'd use the one in the best condition or with the best ratios.
Either way if it breaks you could always put the other one on.
Wil
Nick
Member #: 154
Midlands
i didn't think you could put an A gearbox onto an A+ block? or vice versa. could be wrong though.
You can as long as you use the right flywheel housing and drop gears. The bearing size is different.
Nick
Member #: 154
Midlands
cool! that means i got me a spare gearbox then. sweet!
speedfreaq
Member #: 133
Jamaica
what ratio diffs do you guys run
i have a 3.4 with 10" wheels and there is definately too much wheelspin :s
'I swear to use the Boost, The whole Boost'
'And nothing but the Boost..... So help me God'
gregor
Member #: 98
Slovenia
I run std 3.2 diff with 10" wheels but I suffer on long journeys. So, I would like to try 2.9
