Home > Help Needed / General Tech Chat > Zero deck...
vrooom
Member #: 138
Wont that cause conrod stretch at high rpm and smack the chamber with pistons ?
jay
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Not necessarly, think headgasket thickness!
AlexF
I think Mr Vizard reckoned around 15 thou stretch @ 8k.
Some engine builder's like to have the pistons down the bore a tiny bit (10 thou Max) on large overbores (73.5mm) as the piston can touch the fire ring on the headgasket allegedly.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
I have never seen that happen on mine, I have taken it to 9300 rpm, and have 73.5 mm bore. I have zero difference between the pistons and the deck.
Do you have gasket overhang? What gasket are you using?
Dangerous
Member #: 417
I think wolfie has the pistons +.001" to the deck,1293 with bk450 head gasket
well i said allegedly!!*laughing*
I have "heard" of it but not seen it first hand, It may be a problem that sometimes occur's if you don't offset bore or something.
Edited by Joe C on 19th Aug, 2006.
I tell you this, my Nat Asp 1399 has a shed load of overhang and no other offsetting would make it any better. the BK450 gasket chamber is 73.5mm by 73mm. so even on a 73.5mm bore there is tiny amount of overhang. also note that that is an uncompressed gasket, the chamber would get smaller when compressed.
Edit
Mind you the crown of the piston is about 20thou smaller than the bore any way
Edited by Sprocket on 19th Aug, 2006.
yep mine are proud of the deck by .001 ok to 7k
My N/A engine is 0.02mm positive deck... I haven't taken that to 7500rpm yet, but I will :)
my 1380 engine had 5 thou clearence without problems.
is not that critical
remember the engine design is Some!!!.......... 50 Odd years old
even if you stress them *wink*
