Home > Technical Chat > N/A Vs Turbo??
Clarks.2006
Member #: 1222
Im wondering if a n/a turbo engine would be faster than just a 1275 engine?? thanks clarks.2006
N/A is an abreiviation for normally aspirated, which means non turbo'd.
oh, hang on I think I see what you mean now, will a metro turbo engine with no turbo on it be faster than a std metro engine.
erm, the actual engine is basicly the same, ie same cc, same valve sizes, same camshaft, same compression ratio?
so assuming they are both fitted with the same manifolds, carb& ignition. the power output should be near as damit the same.
Edited by Joe C on 19th Aug, 2006.
Dangerous
Member #: 417
A n/a turbo engine would be less powerful due to lower compression,smaller valves,and low performance cam
