Home > Help Needed / General Tech Chat > steering rack troubles
miniminor63
Member #: 672
The oversills police
Oslo, Norway
Hi
I am using a quick rack (2.2) from minispares. its been on the car for about 4500 km.
When I jack up only one side at the front and try to move the front wheel that is in the air, I can move it quite a bit before the other wheel(that is on the ground) corners together with the one im moving. What could this be? I cant understand that a new rack should have gone bad already? could it be some adjustments or something? I have never opened one up before...
if the track rod ends check out ok
then proceed to check the rack if its secured correctley!
if so the rack is goosed send it back
evolotion
Member #: 83
Glasgow, Scotland
i wouldnt be supprised if the rack is goosed already, im on my 4th rack this year.
Denis O'Brien.
the third from last post may be of interest.
http://www.minimania.com/web/threadid/7409...1/msgthread.cfm
miniminor63
Member #: 672
Oslo, Norway
Rack is fastened correctly and does not move, rod ends are new and in good condition. Dont think it will help sending it back, as it is quite a few years since I bought it, it has been stored for a while before I started using it. Oh well, maybe I should pick up another one when I come over in Sept.
Edited by miniminor63 on 20th Aug, 2006.
