Home > General Chat > SPI exhaust manifold
vrooom
Member #: 138
i looked at it today.
realised that i could use it and not require any bulkhead mod (well hopefully). it might be cheaper alternative to mirage mainfold.
the exhaust port on manifold look bit small. bit the cast iron casting look thick.
the manifold outlet is 90 degrees down from exhaust outet, closer to block. It has lamabda sensor already fitted at bottom of spi manifold. and i can use any carb inlet with that spi.
Do you think i could fit SPI manifold to T2 turbo with adaptor?
the bottom outlet has 2 LCB sytle exhaust hole. in tranigle shape with 3 bolt.
Who are willing to make a adaptor for it if i designed it and will someone make it ?
If you want take a look at pic. just holler i'll go get some pic of it.
I thought about this too.
Anybody know a successful way of welding cast iron? weld a new flange on to it.
vrooom
Member #: 138
500kb pic.
Hope its ok.
