| Home > Help Needed / General Tech Chat > DIY Injection Throttle Body???? | |||||||
12 Posts Member #: 234 Member |
15th Apr, 2004 at 09:32:14am
Wondering if anyone else has attempted a DIY fuel injection system on the A series... I'm currently building the manifold and was trying to work out what diameter throttle body to use. The motor also has a T2 fitted and using the "Megasquirt" ECU. I've made the intake runners and plenum chamber and about to machine up a throttle body on the lathe but deciding what size butterfly to use... I know the metro used the 44mm (1 3/4") in the HIF44 but thinking I might use a HS8 butterfly 50.8mm (2"). |
15th Apr, 2004 at 10:24:04am
44mm butterfly should be ok for typical a-series power (90-200), so long as the throttle is still the biggest restriction in that part of the inlet system.
AlexF |
15th Apr, 2004 at 10:57:29am
I've had two injection systems on mine: Webcon and DTA.
15th Apr, 2004 at 02:10:11pm
the megasquirt diy system is a batch injection type and it will not be possible to inject an aserie with this system.
