Page: |
Home > 998cc > 998 engine spec ADVICE NEEDED! i'm a complete novice engine builder | |||||||
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
23rd Aug, 2006 at 02:59:28pm
Hi, i've just stripped my A+ 998 engine & box, all bolts have come out nicely, i'm just degreasing all the parts to then take for machining, if & where needed
Edited by clubminiflip on 23rd Aug, 2006. SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
23rd Aug, 2006 at 04:15:21pm
Pockets for 12G940 head- only have these done if you are going to use a 1275 head straight away. If not don't have them done.
23rd Aug, 2006 at 04:50:07pm
is this due to it dropping the CR or another reason, i was just going to do it incase i put a 940 o in the future, its not a problem if i cant, i'd build a spare 998 block with pockets, if there is a specific reason tho let me know, cheers SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
23rd Aug, 2006 at 05:40:23pm
Well check out the speck of our engine for a start:
http://www.twin-turbo.co.uk
23rd Aug, 2006 at 07:00:23pm
benh cheers, i think i'll be going with the centre main strapp then, i just was'nt 100% sure,
23rd Aug, 2006 at 09:56:50pm
On 23/08/2006 14:59:28 clubminiflip said:
i may polish the rods myself going by the vizard book I've read that this effect the hardness and the rods need to be shot peened afterwards, has anyone else heard this or am I talking out my arse again? Also don't trust the machine shop to get it right, measure every thing, whilst I have only heard good thinks about Morspeed, anyone can make a mistake and it's better to find out before you bolt it all together. Isambard Kingdom Brunel said:
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
23rd Aug, 2006 at 09:56:59pm
I'd use flat top pistons if you are going to use the 12G295 head. The new Minispares Mega ones should be available soon.
Edited by Paul S on 23rd Aug, 2006. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
23rd Aug, 2006 at 11:37:51pm
been reading the vizard bible again tonight! i think i may give the rod polishing (ooh-eer) idea a miss as i'm a novice to engine building and with this build i dont think its really neseccerry 'but' i think i'll make the point of possibly having the rods balanced end to end & make the point to the machine shop i choose to check for ovaling of the rod ends! & the on the block caps that they are inline & round/correct!
24th Aug, 2006 at 01:30:47am
i've read on here that alot of 998 turbos that ppl have done stick with the standard cam but i've also read that the SW5 in most road going NA applications is a really good choice, i dont feel i'll need top end for the drag strip as you try to change gear before the power drops off (usually top end) so the sw5 is on the maybe list if you've had decent results, what would it rev to?
Edited by clubminiflip on 24th Aug, 2006. SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
24th Aug, 2006 at 01:37:33am
Also reading the vizard book it says the metro turbo rad has 50% more capacity than it needs to keep the metty turbo motor cool, is my thinking correct that this could be a cheap cooling option if i front mount it in my 998 turbo mini, it has to be cheaper than an uprated mini rad? SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
24th Aug, 2006 at 07:33:38am
For the machining that you want any local machine shop should be able to do what you want. there's no point lugging an engine around the country for simple stuff. Porting and fancy head work is Simons skill, so use him for that.
25th Aug, 2006 at 09:28:19am
right i think i have the basics for getting the block crank rods & pistons, sorted,
14th Sep, 2006 at 04:37:52pm
right i've got my initial quote from simon at morspeeds for the block & bottom end & it works out at £390ish including fully lightend & balanced, what i'm asking for ins'nt to far from the mini7 spec bottom end he supplies so i think its not a bad deal, he recommended a turbo cover & bonded plate, verniour duplex timing set, mg metro cam, is this sounding the right sort of ballpark cheers guys SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
14th Sep, 2006 at 05:07:04pm
Sounds OK to me http://www.twin-turbo.co.uk
14th Sep, 2006 at 05:25:29pm
brilliant!!!! cheers for your help & adivce all who have, i think i'm pretty much ok on my spec & i'll get my parts machined, & start the build, i'll include photos in the 'show me yours thread & probobly bug you all with little probs along the way
14th Sep, 2006 at 06:12:04pm
Our mg cam is timed at 110 deg which seems to work fine. Power past 7k. Tghis seems to be the limit of the 20773 pistons though, so get the megas, that's what I'm tryinmg next.
14th Sep, 2006 at 06:50:23pm
have you got the 295 head already?
14th Sep, 2006 at 07:43:44pm
joeybaby83 i have got my 295 head stripped and ready for machining, it looks in really good condition, the only bit that looks iffy is where the heater valve go's on the head but i think it'll be ok, (there are pics in the 'show me yours' of my build)
Edited by clubminiflip on 14th Sep, 2006. SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
14th Sep, 2006 at 07:53:46pm
yeah, cc's = cubic centimeters
14th Sep, 2006 at 07:57:14pm
so i can check this myself, i know a pepete & oild is cheaper than a machine shop price to check it! do the pepetes come with cc's as the main measurement if so where can i get one :oP i feel all warm inside hehe! SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
14th Sep, 2006 at 11:03:09pm
oh yeah! i presume i use the metty turbo carb, are rebuild kits availible for these carbs
23rd Nov, 2006 at 11:16:55am
hi a friend has some AE 22463 pistons, +0.020" oversize,
23rd Nov, 2006 at 12:25:38pm
I've had a good look arouns and I can't find what pistons these are.
23rd Nov, 2006 at 12:32:10pm
They are standard late model 998 A+ flat top slipper pistons.
Edited by Paul S on 23rd Nov, 2006. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
23rd Nov, 2006 at 12:35:12pm
In which case I suggest a maximum of 10psi. Mine fell apart at 15.
Page: |
