| Home > Help Needed / General Tech Chat > Flywheel wont budge | |||||||
236 Posts Member #: 243 Senior Member Portsmouth |
15th Apr, 2004 at 06:59:08pm
Hi all. WooHoo Passed it's MOT!!!! One of the cars in The Portsmouth Mini Turbo Massive!!
15th Apr, 2004 at 07:03:16pm
Tighten up the puller, and whack the 3 corners of the puller in turn with a big hammer, tighten up more and repeat.
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
15th Apr, 2004 at 07:26:25pm
Try just leaving it under load overnight, sometimes it just needs a bit continuous load.
15th Apr, 2004 at 07:56:09pm
I use an air impact wrench, hammers and tightens all in one then!! Seems to do the trick since the whole engine is getting rebuilt anyway. Cant see it doing any more harm than hitting it with a hammer.
16th Apr, 2004 at 01:10:46pm
Thanks will give that ago, hopefully it will come off its starting to get a bit annoying! WooHoo Passed it's MOT!!!! One of the cars in The Portsmouth Mini Turbo Massive!!
16th Apr, 2004 at 02:21:45pm
Try hitting the flywheel from behind through the starter motor hole, turn the flywheel a little then hit it again.
16th Apr, 2004 at 03:03:54pm
Once you've done one stubborn one it can only get better!! I was all ready to grind mine off before i tried some heat on it, i mean cherry red! |
![]() 265 Posts Member #: 68 Senior Member Coventry |
16th Apr, 2004 at 03:19:41pm
Ive found that tightnening up the puller real tight, heating the outer collar up, then giving it a good spray of WD40 usually does the trick.
Sooperdooperturbocooperexpertengineering! |
91 Posts Member #: 236 Advanced Member |
16th Apr, 2004 at 06:08:28pm
Also make sure that the flywheel puller is on exactly square to the flywheel. If you don't pull it perfectly in line they don't like to budge.
16th Apr, 2004 at 09:09:45pm
yes the puller need to be perfectly square to the flywheel , this make a huge difference; I generally check this five time before to start pulling on the flywheel |
17th Apr, 2004 at 04:43:36pm
Jus tried all ya advice left it last nite with some penetrating oil on it then heated it up, then beat it hard a few times still wont budge seems to be really solid. Is there anything else that needs to coe off before i try and pull it off?
![]() 2641 Posts Member #: 19 Post Whore newcastle |
17th Apr, 2004 at 06:10:39pm
sounds like the C clip has dropped ??
17th Apr, 2004 at 06:38:59pm
What part is the c clip? can it be seen from the flywheel end?
19th Apr, 2004 at 01:30:24pm
Do what i did, pay a garage 10 quid to take it off Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
19th Apr, 2004 at 05:59:24pm
Yer rang a clutch garage today wouldnt touch it wit a barge poll lol WooHoo Passed it's MOT!!!! One of the cars in The Portsmouth Mini Turbo Massive!!
its the easy way out
