Home > Help Needed / General Tech Chat > Turbo help needed...
mini300bhp
Member #: 653
Cambs
Hi all,
Im running a standard turbo at the moment but I want to upgrade to somthing a bit better. Im running it at 21psi at the mo, but anything over that (I tryed 27) doesn't make any extra nannas, so just wondering what would be a good turbo. I don't want to spend anything over a grand really.
Also, Im using a minispeed turbo cam, which peeks at 5500rpm, would it be worth fitting somthing a bit hotter? Im not really botherd about drivability, just more bannanas the better.
Cheers, Kev
Its only a bit of metal. If it blows it blows!
http://www.putfile.com/mini300bhp
try a 6:1 cr, t4 and 40psi
mini300bhp
Member #: 653
Cambs
can do
increase to a 1380 cc
phase 2 cam or 649
CR to 6.9: on a witches brew of tetraboost high dose 120 ron
with a larger ar housing
oh! a "well plumbed" large intercooler
As a cheap upgrade try a T3 with a larger exhaust housing, this will flow better at higher boost than the standard Metro unit.
Easiest thing of all - call TurboTechnics and tell them what you want.
21psi is way OTT on a stock T3
Ric
Member #: 36
Basingstoke
Sorry to piss on any fires... and i might be missing something here, but what's the point?
Isn't BHP just pub talk? And if it all comes in in one massive lump (which it probably will with a huge turbo and a lumpy cam) it will just fry the clutch.
I'm all up for seeing something new being tried, but if it's at the total expense of being able to drive it there seems little point.
And to go back to the original point of the thread, why not try some No2. You'll only need a little shot of it and it will cool the charge right down. Massive temps are probably the biggest issue with running high boost.
I agree with Ric, getting the power through the clutch would have to be addressed before going ahead withgetting more nanas.
Have you checked the inlet temp. differences with different amounts of boost?
Trying to squeeze that much air through the a small space is bound to heat it up a fair amount.
If you can cool the air temp down, its going to have the same effect as running more boost surely?
totally agree with ric
drivability is everything
21 psi is actually where the t3 40 trim makes most airflow 70 percent eff up to about 170 bhp then 65 percent up to about 200 , a step up may be the 50 trim or 45 trim from the escort rs ,which also has a larger a/r turbine that would suit higher boost and bhp . ,so for cheap power ,id go for a escort t3 ,and a cam that peaks around 7k ,with a good head and large intercooler .if yuo want higher boost than mid 20's id go for a gt 20 as pete suggests .prob a 2059.
regards robert.
mini300bhp
Member #: 653
Cambs
Cheers boys...
It made 200 on baldwins rollers at 21psi, and that was it. Any ideas what the escort turbo is good for?
Im interested in the gt 20, will it fit straght onto the manifold and what power is it good for?
I spoke to TurboTechnics about a turbo, they said they can put bigger housings on my turbo and make it roller bearing for under a grand but better to ask around first what you boys think before I spent the mulay.
After the rr, the plenum was still cold, so the intercooler in working ok I think. When we tryed 27psi it started to worm up a bit but no pinking....
Im not bothered about drivability as it is not my every day car, and I want to race it when I get my licence.
Also, that does the phase2 cam peek at?
Cheers, Kev
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
I would get those worms out of your intercooler
16V project underway
Stig
Member #: 694
Shropshire
if you are looking for an all out race cam them i think the avonbar phase 3 might be worth a look. However if you do a search on this site i think john and mini williams had a few issues with it when they tried it.
Turbo Tim
Member #: 177
Woburn Sands
phase 3 has a very narrow powerband, not a good acm for a road car
Turbo Tim
Member #: 177
Woburn Sands
phase 3 has a very narrow powerband, not a good cam for a road car
no offence ment but i still find this statment a bit dumb
drivability is everything regardless of what its used for, a miglia still has to have a certain amount of drivability for it to be drivable, this does not mean it can be driven on the road!
again in drag racing if your engine is so peaky that it either bogs or spins when trying to get off the line then its an utterly useless piece of expensive metal
does that make sense or have i had to many drugs today?
mini300bhp
Member #: 653
Cambs
Ok, I mean low rpm drivability, my mistake. Im not botherd if its cack below about 4000 rpm. I didn't build my car for 1/4 mile more for some sprints/hillclimbs and extreem mightys, and only some fun 1/4 mile and road for now. My gearing is quite close, so I think a narrow power band would be ok for what I want the car for.
Thanx
