| Home > Help Needed / General Tech Chat > compression | |||||||
93 Posts Member #: 1212 Advanced Member braintree, essex |
25th Aug, 2006 at 06:57:49pm
how much boost is the safe limit for a stock metro turbo engine with a mirage/t2 and r5 intercooler? |
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
25th Aug, 2006 at 07:00:50pm
prob bout 10psi if set up but very hard to tell, rr it "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
397 Posts Member #: 694 Senior Member Shropshire |
25th Aug, 2006 at 07:03:34pm
before you rolling road it i would only run a few psi boot just to check everything works i.e. fuel presure rises with boot etc. After about 8 - 10 psi |
25th Aug, 2006 at 07:07:33pm
need to build it first, but a rr session would most definately be one of the first things i would do. would 10psi be a nice road engine? |
25th Aug, 2006 at 07:08:52pm
On 25/08/2006 19:03:34 Stig said:
before you rolling road it i would only run a few psi boot just to check everything works i.e. fuel presure rises with boot etc. After about 8 - 10 psi how do u check the fuel pressure rise with boost? |
25th Aug, 2006 at 09:07:28pm
Get a gunson fuel pressure gauge(halford £16 ish) set to 4psi on idle,then stick it on the windscreen behind the wiper.................out for a blast and make sure it stays higher pressure than the boost gauge
26th Aug, 2006 at 08:36:32am
I used 10/12 psi on my first std metro unit which also was intercooled on std c/r, alway use 98 fuel (or more lucky guys ) and it will do a good and very reliable matey.
Edited by fab on 26th Aug, 2006. |
