| Home > Help Needed / General Tech Chat > valve guides | |||||||
43 Posts Member #: 191 Member Falkirk, Scotland. |
25th Aug, 2006 at 08:43:31pm
Got a set of Valve Guides from Minispares and started fitting them. After fitting one inlet and one exhaust, I decided to try the valves in them for fit. The inlets fit ok but the exhaust valves won't fit. Should the exhaust guides be a different size??? |
25th Aug, 2006 at 08:49:38pm
you need to ream the inside of the guides to the correct size for the valves to fit :) turbo 16v k-series 11.9@118.9 :)
25th Aug, 2006 at 08:54:36pm
If they are too tight a fit,due to the valves expanding when hot,they will stick a bit in the guides and get twotted by the pistons
25th Aug, 2006 at 09:46:44pm
Are you trying to fit turbo exhaust valves into a NA exhaust valve guide? Were all the guides the same size?
25th Aug, 2006 at 10:26:14pm
All the guides supplied were the same size. There did not seem to be an option for buying larger guides for the exhaust valves. I assumed the valve stems were all the same diameter.
25th Aug, 2006 at 10:41:20pm
Thanks for the replies guys. I have looked again on the Minispares site and found the correct guides. |
26th Aug, 2006 at 11:01:05am
I think Hoggy can supply reamers, all the guides will need reaming to debur them after the fitting process. -MINI CLUBMAN 1380 TURBO- |
26th Aug, 2006 at 11:01:08pm
all bronze guides will need reaming out after fitting as the bronze swll inwards a tad after fitting.
