Home > Help Needed / General Tech Chat > carb question
Robin
Member #: 1167
Northants
can a turbo carb be used on a non turbo engine?
and is the turbo inlet manifold the same as the manifold sold as part of a stage 1 kit?
if they are the same, that would be good, as i can sell them to my mate who is after them :)
Yes - but it doesn't flow aswell as a nat-asp carb becuase of a silly valve inthe butterfly.
No - and it probably wouldn't give the same power as a correct stg1 manifold.
You could just lie?*laughing*
Robin
Member #: 1167
Northants
lol, cheers Dave.
any idea if a turbo inlet manifold would fit with an LCB exhaust setup?
i'm right in thinking its an HIF44 he needs to buy arent i?
the turbo inlet manifold has a thicker flange, about twice as thick as std.
turbo hogster
Member #: 178
stowmaket suffolk
you can just change the buttery fly like i did
the only advantage on the turbo manifold is that it is easier to get the manifold nuts off and wont do a lot for porformance
Dangerous
Member #: 417
IIRC a mg metro N/A manifold flows 3cfm more than the turbo one
