| Home > Help Needed / General Tech Chat > Not firing | |||||||
![]() 232 Posts Member #: 1197 Senior Member Dublin Ireland |
27th Aug, 2006 at 07:44:33pm
27th Aug, 2006 at 08:25:03pm
more than likely she is running way to lean, but also check for air leaks on carb ect.
27th Aug, 2006 at 09:28:28pm
Cheers mate, Ill check the air fuel mix and go over the carb aswell, I was thinking also it might have something to do with the fuel pressure?
28th Aug, 2006 at 09:42:36am
i suspect that you have a blown head gasket between 2&3 bores if all else checks out
28th Aug, 2006 at 11:27:28am
Cheers Benross, Ill be doing the CR test this evening... Ill update if I find anything out of the ordinary,
29th Aug, 2006 at 10:36:45am
Well I done the comprssion test yesterday evening and nothing showed up, all cylinders are fine with little or no variation, so tonights task is to check the carb and manifolds for any leaks, I might even put on a NA carb to check if the carb is my problem...
29th Aug, 2006 at 08:01:47pm
Sounds like a problem with the needle, when i first got into minis i stuck a stage 1 kit on a 1275 without changing the needle and it used to misfire like hell low down the revs, the only way i could run it was with the choke on. Also are you using an electronic alternator from the metro?? If the bolts holding the module onto the dizzy have come loose this can cause terrible misfiring. But it sounds like a fueling issue to me!
29th Aug, 2006 at 10:58:47pm
leaks like you say check this out fully!
29th Aug, 2006 at 11:55:29pm
Hi Lads, the Dizzy is the 123 Ignition system which has no module but I would have suspected that if I was running the standard Dizzy, I found a small air leak at the manifold so Im going to get that sorted and see if it makes a difference, also It appears one of my leads is working properly intermittently possibly causing the missfire, Im going to put on a new set and get her on the RR to get the timing and fuel sorted, and check the carb again.
