Home > Help Needed / General Tech Chat > pressed steel V's A+ rockers
Dangerous
Member #: 417
Is it true the pressed steel ones are 1.3:1 ratio and the a+ are 1.2?:1*wink*
If so I may as well change them*smiley*
yes your right! & as peter says bri
On 28/08/2006 01:28:14 mini1071s said:
Setting the complete valve train geometry properly with proper length pushrods is worth as much as 5hp it's free HP if you have access to a lathe.
really??? could you pm me this info!! pleeeeeeeeeeeeeeeeeeeeeeeease
Dangerous
Member #: 417
same here
