Home > Help Needed / General Tech Chat > Turning the in and outlet from T2
beestje007
Member #: 1230
IS it possible to twist the in and outlet when reassembling the T2 turbo? for easier fitting? Could this be a problem? So the outlet would be 90 degrees turned... Wich of the 4 inlet holes are for the water? is it the one where u see the shaft? or is this hole for the oil? thanks
Kean
Member #: 341
aka T2clubby
South Staffs
If you mean rotate the compressor housing, this can be done by releasing the circlip and turning the housing.
The hole where you can see the shaft is the oil way
beestje007
Member #: 1230
is it the same when i release the 4 bolts and remove the 2 half circles and then twist the exhaust housing? could it give a problem? and the outlet of the oil is the little hole at the opposite side from the inlet? thanks
