Home > General Chat > Rolling Road Result
I'm on holiday in France at the moment, typing this from the hotel as it's throwing it down outside. I just thought i'd let you lot know ....
Well last friday i finally made the trip down to Peter Baldwins for a rolling road session.
The first run up with no alterations showed 140hp with 10psi of boost, which i was quite pleased with.
We then upped the boost to 15psi and swung the dizzy back a little to retard the timing, this gave a power reading of 180hp.
I decided to try a little more boost just to see if any more power could be gained, though as was doubtful if i'd see much more running the T2. 16psi gave us 184hp which seemed to be the peak, as 17/18psi still gave the same reading. Though the inlet temps were climbing now, 45-50deg or so, as we had no airflow over the intercooler, just a fan blowing on the radiator. Out on the road the charge temps never get near that kind of level, so i may run a little more boost yet ......
Anyway 184hp at 16psi will do for now.
Catch you later.
Phil. *smiley*
Kean
Member #: 341
aka T2clubby
South Staffs
Excellent results Phil!
You must be chuffed
nice one phil!! i was wondering how you got on yesterday
you made it there and back ok then?
giallofly
Member #: 164
The Stig..
Newport Pagnell
PB is the man, good result.
JF.
t3gav
Member #: 229
Gavin@minispares.com
kent
Good result, well done mate.
clubminiflip
Member #: 54
nr coventry
thats i good result & your car has some comforts well done phil
Well done, that sounds just like our T2
nice job phil old chap bet mikes sticking in a bigger compressor wheel as we speak !!
Jackman
Member #: 984
Westhoughton, Bolton
Thats great, quite scared to see what mine will produce when done.
Manchester Minis
well done mate good going.
Excellent stuff Phil, well done!
Carl
Member #: 95
liverpool-on-sea
good result well done phil, should be a very quick car especially now its lighter weight*smiley*
nice result that!
Good stuff mate, get it down the strip now! :-p
1976_mini
Member #: 259
grays, essex
fantastic news, What spec is the engine that are you running?
it may b small but it purfectly formed
http://photobucket.com/albums/v340/1976_mi...roject%20turbo/
Cheers guys, just got back from holiday now. Going to do a few more tweeks this week if it stays fine *wink*
I know Baldwins rolling road may read a little "optomistic" but i'm still pretty chuffed.
Ported/big valve head, forged pistons, 7.8-1 compression, Phase 3 cam, front mounted alloy intercooler, SC box/drops etc
Phil. *smiley*
RED850
Member #: 89
Sydney Australia
Good work Phil, how does it drive with the Ph3, mine was a pig under 3500 and timing at 16-17degrees.
was that figure at the wheels or crank calc
179hp on 12psi 1293cc of pure A series
14.0et @101 mph
well done mate, does this mean you'll be running at avon next year?
superb results phil
whats the cc of the motor ???
iam soon to find out in a few weeks what mine will produce at those boost levels 1380cc and ALL the modds!
Cheers !
It's not to bad with the T2 fitted, i suspect it's a whole lot worse with a T3. Power was at flywheel.
Thanks Jim, yeah if all's still going well i will be.
On 05/09/2006 12:33:41 benross said:
superb results phil
Thanks Benross, 1293cc mate.
Phil. *smiley*
