| Home > Help Needed / General Tech Chat > How good is a T2 & mappable ignition? | |||||||
123 Posts Member #: 1234 Advanced Member Chester |
29th Aug, 2006 at 09:52:46pm
Trying to find out what people think of the T2 vs T3. I have a T3 set up currently and find it a bit laggy. I don't want max BHP, maybe 130-140 so T2 is plenty big enough.
29th Aug, 2006 at 10:09:15pm
well nic on the forum has a T2 with mappable megajolt ignition
29th Aug, 2006 at 10:09:41pm
What lag????
29th Aug, 2006 at 10:11:30pm
Ben - nic was a 13.6 ; and that's not a stock T2.
29th Aug, 2006 at 10:18:19pm
hehe 13.5 actually!!
29th Aug, 2006 at 10:50:00pm
right dave
29th Aug, 2006 at 11:07:43pm
its a mirage jobbie, the second one they do, seems to be good up to 18psi, im not sure if there is much gain to be had at 20.
29th Aug, 2006 at 11:16:01pm
I've got a R5GT spec T2. Looking for max driveability and minimum/no lag.
29th Aug, 2006 at 11:38:36pm
no, thatll be ideal
30th Aug, 2006 at 05:36:54pm
What compression ratio can I get away with running if I go with an intercooler and I guess max 14psi boost? |
30th Aug, 2006 at 05:39:09pm
8.4, or 8.5??? id try 8.5 myself, as i beleive it will give you better low down-ness which is what your after |
30th Aug, 2006 at 06:15:30pm
if your looking for around 130bhp then you may as well stay with the std turbo cam or the mg cam as you may feel the phase 2 at the bottom end, also its a few quid saved. On 28th Aug, 2011 Kean said:
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
1st Sep, 2006 at 10:47:05pm
Nics turbo is an all T2 based unit that has been played around with. The other unit i do is a T2 core and turbine with a modified T25 compressor and housing. Both these units are mapped to suit the a series at around 1300cc, revving to around 7000k. |
1st Sep, 2006 at 11:33:20pm
What are the prices of these turbos?
2nd Sep, 2006 at 03:47:29pm
7000k isn't that 7million rpm.. that i'd like to see lol |
3rd Sep, 2006 at 11:46:20am
Well pointed out!!!! lol These babies sure can rev !!! sorry guys that should have been rpm instead of k.
