Home > Technical Chat > ap racing clutch specs
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
Cover Assemblies Ø180mm - Ø215mm.
Ø180mm - Mini ('A' Series engine) Cover Assembly
Cover Assy Type DS DS DS
Part Number CP2084-31 CP2084-32 CP2084-42
Mounting Holes - mm
Dowel/Mtg hole position 3 Off Ø9.63/9.53 Equispaced on a Ø206.38 PCD
N/A
Set up height (nominal) mm 52.55
Diaphragm spring colour Orange Grey Double Grey
Release plate fitted Yes Yes Yes
Max Release Travel mm N/A
Clamp Load N (lbs) 3114 (700) 4893 (1100) 5560 (1250)
Driven Plate
Thickness mm New Clamped 7.11 (0.28") 7.11 (0.28") 7.11 (0.28")
Min Worn 6.11 (0.24") 6.11 (0.24") 6.11 (0.24")
Torque capacity using driven plate Nm (lb/ft)
CP2084-41 103 (76) 161 (119) 183 (135)
CP2599-11 N/A 161 (119) 183 (135)
Bearing type Flat Face Flat Face Flat Face
thats bloody good fab thanks . looks like there are 2 different driven plates ,both with the same torque rating ,hmmm
Edited by robert on 30th Aug, 2006.
Dangerous
Member #: 417
Sorry to drag it up but any idea what the clamp load is for a std pre verto cover
fab
Member #: 100
Paris\' suburb
blue one?
430 lb for a blue one, according to the tech pages on the mini mania site.
Edited by robert on 12th Sep, 2006.
