Home > Help Needed / General Tech Chat > Carb or injection?
beestje007
Member #: 1230
WHat would be the easiest for placing a turbo an injection 1300 engine or 1275 metro carberator engine?
if you mean the actual engine (block, crank rods, head etc), it doesnt matter which you use.
the fuelling system however that you use needs to be carb unless you are very very very good at sorting the injection.
injecting a 5 port is incrediably hard, even more so when turbo'd.
beestje007
Member #: 1230
oh ok, carb then. *smiley* is it possible to rebuild a HIF44 to a turbo HIF44, with a kit or something? because i can't find a Turbo carb and on avondbar they ask a lot a money
Mirage
Member #: 119
easy, CARB
Ric
Member #: 36
Basingstoke
yep it's possible to convert them. As suggested before, do a search, someone will have written an article about this.
TurboDave wrote a post ages ago on carbs that has helped me massively. Have a look for it. :)
