| Home > Help Needed / General Tech Chat > blow off? | |||||||
113 Posts Member #: 1230 Advanced Member |
31st Aug, 2006 at 09:54:34am
In the chamber where the carb sucks his air from the turbo, there is another liitle hole thats connect with wat? is that a blow off, dump valve? WHats opening the dump valve and how? what do they use to open it when the pressure is high enough? thanks |
31st Aug, 2006 at 10:37:27am
connects to the fuel pressure regulator
31st Aug, 2006 at 06:07:25pm
the hole which dangerous has mentioned is around 4mm diameter,....... its as he says
