| Home > General Chat > Tie Bar Bolts | |||||||
1st Sep, 2006 at 07:00:52pm
Here we go with another of my dull as dish water posts:
1st Sep, 2006 at 07:29:18pm
well 8.8 grade are fine but..... i go over the top
1st Sep, 2006 at 07:30:01pm
yes you nee dto get out more,lol,
1st Sep, 2006 at 07:38:03pm
Another thing to make sure of is that the shank is long enough to go most of the way through the arm and tie bar, as the threads are a slightly smaller diameter and that can lead to movement in the connection.
1st Sep, 2006 at 07:40:48pm
I use whatever's on the floor LOL
AlexF |
1st Sep, 2006 at 08:41:13pm
cable ties??? |
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
1st Sep, 2006 at 10:20:51pm
Use caps. these are best for stressed high loads situations. As Tom sais it is important that all the loads from the components are supported on the smooth area of the bolt ( Called the Grip also commonly called the shank). The thread is only there to put a nut on or to screw into thread, Not for supporting loads. |
1st Sep, 2006 at 10:56:23pm
USE ALLOY. |
1st Sep, 2006 at 11:03:46pm
On 01/09/2006 22:56:23 fastcarl said:
USE ALLOY. Why alloy? I'd have thought it would have a weaker in terms of shearing than steel. I'm also assuming that the nut doesn't need to be as high a specification as the bolt as tensile force is less than the shearing force. Right I'm off to look for a pair of grade 8.8 bolts with long shanks and a woman, anyone got the number for screw fix
1st Sep, 2006 at 11:31:12pm
I *think* Carl is referring to alloy STEEL bolts....
2nd Sep, 2006 at 07:17:46am
i wondered how long it would take you clever Tom, |
2nd Sep, 2006 at 07:23:52am
your right carl, i need to get out more! buddy.........lol
3rd Sep, 2006 at 10:58:21am
Generally speaking the BZP nuts you get from propper suppliers will be fine. Remember the bolt has to endure all its tensile load through its cross section. The nut on the other hand is kinda in compression and the force is spread over a number of turns of thread into the body of the nut. As a general rule you should have 1.5 times your bolt diameter to thread into. So if your using an 8mm bolt you should be able to screw it into 12mm of female thread.
3rd Sep, 2006 at 01:03:38pm
thast greet info there Mirage (whats ya real name I can't call you that lol).
AlexF |
3rd Sep, 2006 at 01:24:35pm
so wheres a good bolts suppliers then in the northwest or tinternet, theres one near my work but they dont sell individual items you have to spend a fortune. and id often worried about them little tiny bolts on the tie bars. no longer a series, but still 1.3 turbo.
3rd Sep, 2006 at 01:52:38pm
My names Richard but everyone calls me Barney.
3rd Sep, 2006 at 02:11:02pm
On mine I used 998 rod bolts and drilled the arms out to suit, they have a nice shank to locate on and A+ head or big end nuts fit, all high grade items from the spare bits bucket!
