Home > Help Needed / General Tech Chat > fuel filter where
Dangerous
Member #: 417
Still got the standard plastic one on mine,I have done a search and found to use a steel one between tank and pump.
So I take it you do away with the one under the bonnet between fuel reg and carb ?
Ben H
Member #: 184
Melton Mowbray, Pie Country
If you put one before the pump there is no need for one after.
However, apart from the standard mechanical pump, you should always fit a filter before the pump or it could degrade very quickly. Especially a high pressure roller vane pump.
http://www.twin-turbo.co.uk
Dangerous try a filter from a VW Polo 1995, it is a metal encased filter with 8mm tails each end, a decent size too.
I personally am running the standard MPI filter under the car, and then another one between the reg and the carb, overkill maybe!
Dangerous
Member #: 417
What so you are using 2 X VW Polo 1995 filters.
I don't trust that plastic one under the bonnet (so want to change it)and don't have one at the back...But am running of a brand new fuel cell and all the fuel is filtered when mix it with the lead/octane boost stuff.
I use 1 x Late MPI mini filter in the standard place on the rear subframe
and then
1 x VW Polo filter mounted under the scuttle, plumbed between regulator and carb.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=3048
