Home > For Sale > Small jap alt
Dangerous
Member #: 417
went to scrappy today and got 2 ,so one for sale for a £15
wired it to a batt and span it up with the drill getting 14.6 volts on a battery so presume its ok
bit dirty,got plug,needs pulley changing as its a flat 4 14mm shaft
Its the type with one 60mm wide mount and one 20mm wide got the long bolt too
about 6" long 4 1/2" dia
Can post/ paypal
Kean
Member #: 341
aka T2clubby
South Staffs
Any chance of a pic of it mate?
Dangerous
Member #: 417
should be some on here
http://www.putfile.com/dangerous
I think either the wide lug has to be shortend,or the narrow lug is the same width as the waterpump so will require a steel bracket each side so its mounted in front
Still about 1 1/2" more space at the front of the engine
SumpNut
Member #: 28
PM sent mate!
