Home > Help Needed / General Tech Chat > COIL SPORTS LUCAS
QuimFintas
Member #: 1021
Portugal
hi, con tell me if the coil lucas sport dlb 105 is a good coil to a mini turbo engine?
Daniel Machado
If its the gold coloured one its not for use with the metro turbo dissy, or any dissy that has an electrinic module on the side.
dissy's are ballasted/non-ballasted specific.
QuimFintas
Member #: 1021
Portugal
the coil is this.
Carl
Member #: 95
liverpool-on-sea
that no good for a turbo. its only for ballasted ignition systems. there designed to run on 9v not 12v and will sooon burn out.*smiley*
colas
Member #: 102
Pennsylvania USA
DLB 198 is the one for the turbo.
andeh
Member #: 97
Near Daventry, midlands
those gold coils are u/s, i think your better off with a new std one
redwing
Member #: 1574
Malta
I know this is an old post but for elec dizzy you should use the OEM coil for the electronic ignition - (Part number GCL143 (LUCAS DLB 198 or the Duleclier coil GCL 143), plus non resistor plugs with a 0.035 gap, and a full fat 12v supply. I'd also recomend NGK B7ECS or up to 10psi boost or B8ECS above that.
c2_mad
Member #: 4215
hi guys
any idea where i can get these parts from. the dizzy cap, the "arm" thing for the dizzy, hope that makes sense and the coil. its all for the metro turbo engine.
cheers
That all depends on the ignition leads. If you have resistor leads, then you want a standard plug, if you use non resistor leads, you want resitor plugs.
NOT BOTH
Resistor plugs choice - BPR6ES BPR7ES BPR8ES
Electronic ignition needs some resistance somewhere to reduce electrical noise (suppression)
Make sure the resistance of the lead and plug are no more than 5K ohm
Edited by Sprocket on 13th Dec, 2008.
The DLB 105 is non ballast
Paul
Edited by paul wiginton on 14th Dec, 2008.
