| Home > Help Needed / General Tech Chat > Megajolt controlled variable boost. | |||||||
138 Posts Member #: 138 Advanced Member |
3rd Sep, 2006 at 01:55:23am
Is it possible to set megajolt, when you drive normally, turbo is running in low boost, but when you doing Wide open trottle, programmeable output change the boost level of turbo by using solenoid controlling the actuour or something like bleed valve?
3rd Sep, 2006 at 09:59:40am
i think you could do it with revs or manifold pressure as it has some programable outputs, but a simple switch on your gearstick would probably be easier and better to do. no longer a series, but still 1.3 turbo.
567 Posts Member #: 102 Post Whore Pennsylvania USA |
3rd Sep, 2006 at 02:30:37pm
Hi
3rd Sep, 2006 at 02:36:42pm
Easy in theory. You'll soon get sick of it however. On 17th Nov, 2014 Tom Fenton said:
3rd Sep, 2006 at 06:09:59pm
On 03/09/2006 14:30:37 colas said:
Hi You have 4 programmable outputs on the MJ. Its real easy to setup. They are controlled by RPM. or by MAP. Alex AlexF |
